SUB D
N5NHJ
N5NHJ Member ✭✭✭
Based on to the API Wiki, the command SUB D should dump a list of actual subscriptions.
I always get a malformed command error:
C101|sub d
R101|50000016|
What am I doing wrong?
    edited November 2024
    Hi Max, I was unaware of this command. I don't see it in the wiki…
    In any event, try sub d all
    I tried it and it does not give the error, but I don't see what it does.
    EDIT: Aha…
    S28380B20|stream 0x20000000 type=dax_iq daxiq_channel=1 pan=0x40000000 daxiq_rate=48000 client_handle=0x02559FE9 active=1 ip=192.168.0.24
    S28380B20|radio daxiq_capacity=16 daxiq_available=14
    S28380B20|stream 0x20000001 type=dax_iq daxiq_channel=2 pan=0x0 daxiq_rate=48000 client_handle=0x02559FE9 active=1 ip=192.168.0.24
    It gives the same result as sub daxiq all
    Hi Max, I did some more poking around and see that sub d is a SmartSDR command line API command. I don't know how to start SmartSDR as a command line app, so maybe someone can chime in on that.
