Spot colors
Probably not because N1MM, being archaic and not Flex aware, has no way to interface with the Flex API. Someone here might have info to prove me wrong.
You can interface N1MM with SDC but then as a default you get a color on the Flex Panorama for unworked stations and when worked and turned grey in N1MM they disappear from the Panorama for that band. No sense in cluttering the screen with stations already in the contest log. You can set SDC further to get colors for multipliers etc if you want to go beyond the default.
But if you are going to do that, better is to use SDC Contest and have a fully functional suite that is Flex aware and does so much more than N1MM.
Below is an example where Spots are unworked and disappear when worked in SDC Contest.
Dear Erik,
As I can understand, the N1MM database (valid registered contacts) does not cooperate with FLEX to capture them in the FLEX panorama as WORKED or NEEDED QSOs. Right?
Much less be able to capture multipliers (!)
So, the solution is to look for another contest log that might do that—if, of course, such a thing exists and can be done.
Obviously, the Win-Test by F5MZN won't do it either.
I haven't tried SDC Skimmer. But it's a good opportunity to try it out.
Thank you Erik for the answer.
73 de SV2AEL Savas0 -
Hello Savas - yes correct, N1MM cannot do it without help from a Flex compatible program such as SDC. Win-Test will have same issue.
Do try SDC. In my document
there is a section about interfacing N1MM with Flex radio SSDR. SDC also has its own Contest module (for registered versions) as well as CW/RTTY skimmer, Panorama control, automatic AGC-T and so on. Yuri UT4LW is the author and mastermind and he can answer any questions you have.
I will do it immediately! Thank you Erik again for your prompt reply and your valuable help.
Vy73 de SV2AEL Savas0
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
