iPhone as phone patch.
Has anyone experimented with using an IpHone as a phone patch? I am currently using an external line and patch, but would like to use my iPhone instead.
Hello @edwinhigg , I did a search on YouTube and found something (from 3 years ago), that talks about patching audio from a laptop to a cellphone. Part 1 explains using an audio mixer, and Part 2 (at 14:15 minutes in) removes the mixer completely and just uses RCA cross connectors. The only issue is that the cellphone example in this video uses a audio jack into the phone… your newer iPhone likely no longer has this port and you will have to find a dongle that breaks out USB-C to separate external mic and audio jacks.
The video uses Zoom as its example audio input to a cellphone but the same concept should apply for audio from your radio to the cellphone as well.
The video is NOT radio specific but I thought it might help with some of the basic concepts until someone else in this thread chimes in with their idea. Good luck. John/WA7UAR0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
