CW SIDETONE IN REMOTE OPERATION - new flexUser :-)
I'm not certain I understand the question, but there is a product called the "HaliKey" that connects your key to your computer and generates a local, low-latency side tone for remote operations.
See https://electronics.halibut.com/product/halikey/
Thanks for the quick reply but that devise is for operate in cw with paddle via usb socket. Here I use a contest logger like n1mm or Win-test to generate cw. My problem is i can't eard cw sidetone in my headphone during transmission. 73 Pat F6IIT0
I think I understand. You are using Smart SDR for macOS (SSDR Mac) to operate your Flex, correct? If so, I would recommend you use SSDR Mac along with the HaliKey to generate your CW sidetone, and not N1MM or WinTest.
See:
and look at the CW Keyer section. That document also discusses the HaliKey.0 -
I operate the flex with SSDR for windows and SSDR-CAT with one comm port as CAT system and another to emulate winKey. In n1mm or win-test the setup is easy and it run's well. i'd just like to ear cw sidetone :-) during transmission. I'll check about Halikey does.0
Understood. Your question appears here in the SSDR for Mac forum and that’s why I mentioned that macOS app.
You may want to visit the Windows Smart SDR forum and post your question there for further assistance.0 -
Oh sorry for the mistake - i'll post it on SSDR for Windows. King regards1
I,m also using N1MM remotely with SSDR to a 6600. I can see that the 6600 is being keyed by N1MM but there appears to be no way the actually hear the sidetone generated by the 6600. I may be missing something, I'm no software genius, but you would think Flexradio could have solved this problem by now. I love the Flex, but it's frustration.0
Local Flex: N1MM keying is only heard at the radio speaker connections. SSDR will not send audio back to a different control (e.g. N1MM WinKeyer back to a Maestro or the computer)
I have seen some alternatives. This question is further complicated by remote. I am also looking for an answer in my future configuration.
I think you can fix this by using the Flex Maestro-C
There is an inexpensive product called the HaliKey by Halibut Electronics that facilitates a local CW sidetone for folks using SSDR for Mac. Not sure about Windows, though.
You may want to post in the Windows forum. Good luck!
730 -
Not sure if this thread is specific about the Mac.
For Windows users there is this free software option:
While this solution is implemented in hardware and is independent by the OS.
- 310 Community Topics
- 564 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 153 SmartSDR for Maestro and M models
- 382 SmartSDR for Mac
- 253 SmartSDR for iOS
- 240 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 99 FLEX-8000 Signature Series
- 882 Maestro
- 49 FlexControl
- 837 Genius Products
- 431 Power Genius XL Amplifier
- 295 Tuner Genius XL
- 111 Antenna Genius
- 261 Shack Infrastructure
- 182 Networking
- 426 Remote Operation (SmartLink)
- 132 Contesting
- 681 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 910 Third-Party Software
