Smart SDR Smart Link Check
KG5PTE
Hello I ran this smart link test on my IMAC and noticed it gives more information than the Windows version does. But what is hole punch fail ? I had a help desk ticket on this smart link issue. FLEX support had to team view remote into my ASUS RT-AX82U to get it working the TCP **** was working fine but the UDP port kept failing. From my understanding UDP ports are kept closed by default.
Hi James,
I just used SmartSDR to connect to the original source and encountered the same situation as you. I would like to know if you have solved this problem?
Hank Tang BV2NF 730
- 373 Community Topics
- 101 SmartSDR+
- 424 SmartSDR for Mac
- 940 Maestro
- 54 FlexControl
- 999 Third-Party Software
