Can't add new com ports after corruption.
My F 6500 is running 3.8.19 and just lost com port communications to other apps such as Logger 32. When I checked in the CAT tool, only TCP Port 5002 slice A and VARA Monitor TCP port 8350 slice A were present. I tried to create a new port for each app and noted it started at port 10. A quick check of ports in Windows 10 showed all of the old ports were present.
I used Tim's procedure to delete all of the ports, rebooted and tried again to create new ports.
I get a message: "The virtual serial port (VSP) failed to create. Double check the serial port settings" Further attempts were unsuccessful so I then used Tim's procedure to reset the CAT.settings file, using %APPDATA%\FlexRadio Systems. This did allow me to remove that file. I rebooted and launched SSDR and CAT.
This still did not allow me to create new ports. Only the Flex Control knob works at this point. I am unable to create new ports despite several tries of each procedure. I had experienced this years ago but the procedures had allowed me to correct the issue and I was able, at that time, to create new cat ports.
Any thoughts would be greatly appreciated. 73 All, Jim KD1I
  • James Del Principe
    James Del Principe Member ✭✭✭
    Answer ✓
    OK, update… May be helpful to anyone who may experience this. Mike opened a helpdesk ticket for me. (Thank You, Mike) and I received a quick reply. I was given the document: "How to repair the FlexVSP Virtual Serial Port Driver". This procedure did solve the problem ! I was able to recreate all my CAT ports. It really was easy to do. Thanks again to all the great Flex guys for all their support. 73 all, Jim KD1I
  • bahillen
    bahillen Member ✭✭✭
    I am having the same problem. Ports that were set up don’t work.
    I don’t use these ports very much.
    Bill
    W9JJB
  • The ports I had worked just fine for a very long time. They stopped working so I tried to delete them and recreate as I had done in the past. I was not able to do this as stated above. I tried the procedures that Tim published what were successful in past years to no avail. I use these ports for Logger32, FLDIGI, Winlink, VarAC and more. It would be very nice to have them back.
  • FWIW, I just did a factory reset and reimported my profiles. While that did work, it did NOT solve the issue of the CAT ports. I still cannot create any CAT ports. Honestly, I am out of ideas for now.
    Any input would be welcome. Jim KD1I
  • As a last resort, I just upgraded to release 3.8.20 and did a cold reboot of the radio and computer. No joy in Mudville. I think the answer is above my paygrade.
    Hi Jim, I would submit a help desk ticket.
  • Hi Len. Yes, I suppose I will need to do that… I had hoped that some members would have offered a practical solution. This can't be the only radio that experienced this issue with the CAT ports… When I experienced this in the past, Tim's procedures resolved it each time. Thanks for the suggestion. Best 73, Jim
    Jim, I opened a support ticket for you.
  • Thank you, Mike. I do appreciate that. I am at wits end with this. First time in 12 years I could not solve a problem. 73, Jim
