updated hamlib may be necessary when using JTDX with FLEX-8000 series radios
hamlib (available from github) will need to be updated. The selection still appears as FLEX-6000 however the updated hamlib will recognize 8000 radios.
Yes indeed and you can make it easy to do by invoking the update facility within the software
I have updated Hamlib. I also swapped out the Hamlib .dll files in JTDX. Still no luck connecting to my 8600M. WSJT-X works fine.
Any ideas?
Tim VE6SH
I can confirm that this improved version of JTDX works well with both series 6000 and 8000 radios
Tom
Yes it does but then so does the latest version of JTDX though you may need need to update HamLib as noted by VA3CW.
The so-called "improved" version is actually out of date both in performance and features. For example the Superfox mode for Hounds is only in the latest version.
I downloaded and installed the latest version of Hamlib from Github, no joy. I don't see anything in the documentation on Hamlib about an update function. The link for the jtdx-2.2.260-win64.exe doesn't download for me.
Latest version and there should not be any need to update HamLib but that is done from within JTDX
The rig selection stays the same whether 8000 series or 6000
I just upgraded to version 160 of JTDX using link from Erik and it works great with 8600 using TCP.
Steve0
- 354 Community Topics
- 619 The Flea Market
- 8K Software
- 4 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 220 FLEX-8000 Signature Series
- 927 Maestro
- 898 Genius Products
- 457 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 979 Third-Party Software
