8600 Accessory Connector PinOut
Does the DB-15 acc connector on the 8600 have the same/similar pinout as the 6500 series?
The 8600 Quick Start Guide directs one to the Hardware manual but the manual doesn't seem to be available.
_..—
Tim K3Tim/7
Hi Tim, given that most of the rest of the radio is the same hardware, I would bet that the ACC connector is the same as the current 6000 series radios.
Hi Len
That seems to be the case. Using a cable from the 6500ACC on the 8600 worked as expected.
Thanks for the response.
BR's // Tim - K3Tim/7
Excellent! Always good when you don't have to rebuild connectors. They're not all that difficult, just tedious.
One change in connectors is the CW key. Now a 3.5mm diameter; a change from 1/4" diameter.
I think that changed with the 6400 and 6600.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
