How do I set up a USB port on the flex 6400 to send frequency info to a Hamation MD-12 Decoder?
Hi Allen,
If you haven't done this already, in SmartSDR, go to Settings, USB Cables…
Select an unused cable position and click the Edit button. Give it a meaningful name (in my example, this is for my KPA500 amplifier). Set the cable type to CAT. Set Source to whatever makes sense, most likely TX Slice so that it has the right antenna when you transmit.
You may or may not need to set the RS-232 parameters in the Advanced section.
Post back here with your progress.
I set mine up the same as yours except for the speed. There was no guidance for setting speed. when I look at the log I only see rx no tx. When the PB28 is disconnected from the MD-12 data stops streaming. So some is coming to the 6400 but not going to the PB28 antenna switch comptroller. Should work but it doesn't.
When you click the Edit button for your USB cable, does it show a serial number?
Yes
Ok, it sounds like you have a proper cable. I would contact Hamation. I am guessing thai it is a setting or two away from working.
Len, Thanks for your help. You are probably right on the next step. Hamation is a one man outfit so it might be slow to get any answers but I have patience.
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
