No Band Scope, No Waterfall.
Working my 6500 remotely this morning I discovered that I can no longer get a display of the bandscope or the waterfall under any of my profiles.  When it first boots up there is a large triangular area sloping to the right and any tuning leaves a blank waterfall and no profile on the band scope.  The radio is functioning normally otherwise (tune, transmit, and hear other stations)
  • Stephen VA3KXP
    Stephen VA3KXP Member ✭✭
    edited December 2019
    I have had this happen to me. The radio worked normally when using locally, but no waterfall or band scope when running remote. I ended up deregistering the radio from SmartLink and reregistering. After checking the ports (which were correct), everything worked fine remote again. I was never able to figure out what happened or why it happened., but this cured the problem for me.
  • Steven La Mascus
    edited December 2018
    Thanks, I will check that out.  However the problem continues now that I am back at home so I conclude it is some display bug or setting that I have **** up.
  • bahillen
    bahillen Member ✭✭✭
    Did you reboot the radio.
  • Steven La Mascus
    yes, and I am reloading the program now.
  • Stephen VA3KXP
    Have you tried rebooting your router?
  • Steven La Mascus
    No but I will try that.
     It is a MacBook Air running parallels, and DogparkSDR works with band scope and waterfall. Not Sure where to go next.
  • Julie KC0TMD
    Julie KC0TMD Member ✭✭
    edited November 2024
    If the band scope keeps dropping out every so often, what is going on? Sometimes the best scope will work. Sometimes the scope will be blank and off-line for days. Another time it will be online. It will be fine for days.This particularly common with the SDR. So what I have to do now is log out of the STR hooked the radio into the maestro mode. And then there’s no remote I have to reboot the radio, and then the band scope comes back.
    Is there anything I can do to fix this so problem doesn’t occur anymore because it’s getting frustrating because one time I was it was without a band go for a month and a half.
  • David Decoons, wo2x
    I read somewhere latest MAC update firewall may be blocking UDP traffic to the app. Make sure MAC firewall allows all traffic to and from radio IP.
