FLEX 6400 Remote Power Up circuit?
W4AFK Bruno
The manual says that we short the RPO to power-up and open it to power-down. The manual also says not more than 3.3 Vdc.
Is the RPO circuit …
A transistor?
A physical relay?
A solid state relay?
Use a dry contact relay to shortbthe Remote Power On RCA jack on back of radio.
no need for any voltage to the jack.I use a DLI AC Relay off one outlet of DLI Web Switch Pro. The AC relay has 120 volt coil and a common, normally open and normally closed dry relay contact out.
Dave wo2x0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
