Power Limited to 10w
KI5ESV
So, no matter what I do on the Band Settings table, I cannot adjust the output power on the radio (Flex 6600) )any higher than 10w. This is true on the TUNE option as well.
I have a Mercury III linear on ANT1 and an end fed Dipole on AMT2. The Band Settings table seems pretty useless, it just follows the slider setting,
What am I missing?
What am I missing?
BTW - Flex 66000
In SSDR Settings > TX, what do u have set for Max Power. If 10, set it higher
AL, K0VM
In Settings, TX tab, check that you have Max Power set to 100.
Thanks, That was it!
( Hint to the software team... Seems like those things should all be in one place.)
Thanks again, 73.
Jim-0
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
