Power Limited to 10w
KI5ESV
So, no matter what I do on the Band Settings table, I cannot adjust the output power on the radio (Flex 6600) )any higher than 10w. This is true on the TUNE option as well.
I have a Mercury III linear on ANT1 and an end fed Dipole on AMT2. The Band Settings table seems pretty useless, it just follows the slider setting,
What am I missing?
What am I missing?
BTW - Flex 66000
In SSDR Settings > TX, what do u have set for Max Power. If 10, set it higher
AL, K0VM
In Settings, TX tab, check that you have Max Power set to 100.
Thanks, That was it!
( Hint to the software team... Seems like those things should all be in one place.)
Thanks again, 73.
Jim-0
- 310 Community Topics
- 565 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 384 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 106 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 841 Genius Products
- 433 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 266 Shack Infrastructure
- 187 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
