Flexradio 6400 has yellow dot says update...then it says radio updates not available at this time.
John K6VFR
Because it won't update, I can't start it…not sure what to do…any suggestions? Is there another way to update? Thanks, John k6vfr
Are you trying to do an update to SmartSDR in your radio or on your pc? Check your internet connection. Otherwise, open the Version Chooser and select the version you want to install or update. You can always just select the current version already installed on your 6400.
Hi John, is your network (with the radio) connected to the Internet?
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
