Flexradio 6400 has yellow dot says update...then it says radio updates not available at this time.
Because it won't update, I can't start it…not sure what to do…any suggestions? Is there another way to update? Thanks, John k6vfr
  • Trucker
    Trucker Member ✭✭✭✭
    Are you trying to do an update to SmartSDR in your radio or on your pc? Check your internet connection. Otherwise, open the Version Chooser and select the version you want to install or update. You can always just select the current version already installed on your 6400.
    Hi John, is your network (with the radio) connected to the Internet?
