3.8 Win 11 no dax showing in sound screens
Driver error showing on dax screen and I see all the dax speaker and mic stuff is gone in sound settings…Ideas?
When you installed SmartSDR did you check the boxes to install DAX and CAT during installation? Also, there is a setting to start DAX and CAT ( either one actually if you only need one) when SmartSDR starts up. If you have done all the above, and have the same error, then you may need to change a setting in the Windows Firewall to allow DAX and/or CAT to access your network. One way to test if Windows Firewall is blocking DAX is to temporarily turn off Windows Firewall and then run SmartSDR and DAX. If it works like you expect it to, then you will need to make an exception in the settings in Windows Firewall to allow DAX to run.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
