3.8 Win 11 no dax showing in sound screens
Jim Brinza
Jim Brinza Member ✭✭
Driver error showing on dax screen and I see all the dax speaker and mic stuff is gone in sound settings…Ideas?
  • Trucker
    Trucker Member ✭✭✭✭
    When you installed SmartSDR did you check the boxes to install DAX and CAT during installation? Also, there is a setting to start DAX and CAT ( either one actually if you only need one) when SmartSDR starts up. If you have done all the above, and have the same error, then you may need to change a setting in the Windows Firewall to allow DAX and/or CAT to access your network. One way to test if Windows Firewall is blocking DAX is to temporarily turn off Windows Firewall and then run SmartSDR and DAX. If it works like you expect it to, then you will need to make an exception in the settings in Windows Firewall to allow DAX to run.
