Maestro C won't connect to my iPhone
My Maestro see's my iPhones hotspot, and I am entering the password correctly, the phone ins right next to the Maestro and is the strongest signal it sees, BUT it will NOT connect…any adivse?
Does your iPhone use any punctuation in the SSID (the network name)? Frequently Apple will auto-name your hotspot SSID like "John's iPhone" and the Maestro cannot work with the apostrophe. If this may be your case, re-name the WiFi SSID to something with ultra-plain letters only and re-try.
HTH
Initially it did have the apostrophe, I renamed it without…still will not connect…
On iPhone hotspot screen select "maximize compatibility". Forces everything to use 2.4ghz mode.
I have found that to connect to the hotspot on my iPhone (It's an older iPhone X), you must have the Hotspot screen open on the iPhone when you connect, THEN you can close the screen on the phone. I have had to do this to connect my DMR hotspot to the phone.
Charlie KB8CR
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
