Flex 6600 Version
That would be a question to ask the Help Desk. But, with the new version of SmartSDR, the WNB will work ( in many cases,but not all) for both the older generation of 6000 radios and the last version before the 6000 radios were discontinued to make way for the 8000 radios. Either way your radio, if running version 3.8.19 should have a working WNB. Whether it will actually help for your specific noise situation depends on the type of noise you have. Unfortunately, the WNB is not a one size fits all solution. It works for some noise sources and not for others. You just have to try it and see if it works. ( be sure to give it time to work as it doesn't work instantly)
The story from Steve Hicks is there was a noisy power transformer near the Austin site. The WNB was developed to cancel that type of regularly repeated noise. It doesn’t affect my noise at all.
I had power line arcing here. On some bands, 40 especially, the noise floor was 30 dB higher. I found when WNB was released it dropped my noise floor 20 to 30 dB and made it from unusable to being able to work weaker signals. Steve used some of my video in his early presentation of effectiveness of WNB and power line noise.
I find a level of 93 with preamp on 40 at zero gave best results
Again In my case it was arcing on the primary to my neighborhood, which terminates on one of two poles on my property. I have videos of it in action on my YouTube channel.
here are a couple of videos
https://youtu.be/CXo4hYKqIVM?si=VG4XTSjcZ2-mqHGF
https://youtu.be/Y1mKxHuXLKo?si=QUeZFNao3NI2X7ek
73Dave wo2x
The WNB worked great on the pulsing noise from the neighbor's electric fence around their horse pasture. Now the horses are gone and the fence has been turned off.
73 de K1ESE John
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
