3.8.19 - New Squelch - great addition - but may need work on the controls visuals?
Thanks Flexradio for the recent update 3.8.19
Great to see the new squelch option, however, is it just me but the controls need some tweaking ?
Should have said - On windows 11 Pro (10.0.22631 build 22631) on a 4K display
Best Answers
Are you using 6400 or 6500 ?? Looks ok on 6600 but that has a DIV button below SQL. DIV is not available on the 64/6500.
AL, K0VM
That does look like it is clipped off at the bottom. Thanks for pointing that out. I entered this in our system as SMART-10449.
Hi Don, it is the flag that has the squelch display off a bit.
Hi,
Thanks Al and Eric.
Yes I'm using a 6500.
Ray
It looks fine on my 6700 running SSDR 3.8.19
Maybe it's a 'not correct font installed' issue???
Thanks for the hint Don,
I must admit I did check that the fonts were loaded before posting.
The issue appears only on the slice's "flag" panel and not the pop-out edge panel as you show in your post.
Cheers
Ray
Hi Ray… I checked the flag on my 6700 and I don't see the clipping you're referring to… It could be that, on the 6700 the flag includes the additional DIV function…
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 286 Shack Infrastructure
- 201 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
