Maestro-C doesn’t provide Touch-Screen or Mouse capability to external monitor output
Dewey WØYWW
Dewey WØYWW Member ✭✭✭
I cannot find an external monitor that supports touch screen capability via its HDMI input.
HDMI connections do not support touch-screen. All of the many external monitors that I researched, require a USB-C Thunderbolt type input for touch-screen (as noted in monitor documentation). I tried USB-C to HDMI adapters and adapter cables, but they don't work. Nor does a mouse work with Maestro HDMI output connected to a PC monitor.
So, do I correctly assume that I need to give-up pursuing these options?
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    Answer ✓
    The “M” models don’t support them via the HDMI outputs, either. The purpose of the HDMI output is simply to mirror what is on the Maestro/M model screen.
