Can I use two Maestro's with one flex 6600?
pa1t
Hi all
For vhf two meter contesting I am running with a meastro (slice A) and N1MM. I would like to look for multipliers and make qso's with a second radio on slice B. Is this posible?
How do I connect the second meastro at the same time to the radio. I use two computers. One for Run radio and one for multiplier radio.
Any help would be appriciated.
73 Timon PA1T
www.pa1t.com
73 Timon PA1T
www.pa1t.com
If there is not more to your requirement than you state, run on Slice A and multipliers on Slice B, I do this easily without 2nd Maestro and without 2nd computer. See an example at
If you want to separate out the Slice activities, the 2nd computer can be replaced by a 2nd keyboard
But of course, if you want a more complicated solution, simply run your Maestros as clients in Mutiflex mode.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
