Static IP Addresses in FlexRadio 6600M
Hi,
I have a Flex 6600m and I am connecting to a COX mesh network wifi. The Lan works well with the 6600m, the PGXL and the Tuner Genious XL.
The problem is getting the front panel of the 6600m to get the corectly assigned IP address.
The port forwad address in the router is 192.168.0.230. This is the IP address of the front panel. I want the IP address set to 192.168.0.230 for the Radio. I try to change the IP address in the radio and it will not take the .230 I have the advanced network settings set to .230
I have the portforwarding set in the cox wifi and it has picked the address 192.168.0.230 for the flexradio.(I cannot change that)
However it will not change the front Radio to .230.
When I input the gateway 192.168.0.1 it changes on the radio display to:
fe80::4275:c3ff.feec:781f%12
Whaterver that is?
I would like to remote in from my office and this will not work as is.
Any suggestons?
Thank Yoiu
Chuck Bigbie N5ANY
change the front panel to a differen5 192.168.9.x IP and reboot radio. Then once that is done, do a DHCP reservation in your router for .230 to the radio MAC address. Set the radio to DHCP and reboot.
Dave wo2x0 -
Hi Dave the cox router will not allow you to make a dhcp reservation.
the router allready has the .230 reservation in it.
wait. You mention the “COX” router has .230 port forwarded. Do you only have one router or two? (I’ve seen people with two).
You can change the front panel to 192.168.0.242 then reboot
Bot Cox router and radio then you should be able to set radio to .230 and reboot radio.
Reason O recommend reservations over static and s down the road the router gets changed to newer model which let’s say is 192.168.1.x. You’ll have issues accessing the radio.
I have one router the cox wifi.
I am using the wireless mesh netork from Cox.
This is what it says I changed the 230 to 242 and the 236 to 230 and rebooted. the front panel shows both ip addresses to be .230?
Is .230 inboth places ok?
Well that did it. lost connecton and radio wont work. I guess I have to reset the radio.
Well at the current setting I can remote in from the office!!! YEA!! so I will stop here.
Thank you for all the help.
Chuck N5ANY 73"s
Looking at the first picture it showed a subnet mask of 255.255.255.248. That is not right.
If you have issues going forward, it may be beneficial to have someone with network experience come in and help you.
73 Dave wo2x
Hi all
I did the update to SmartSDR 4.1.3. And the IP address section of the radio changed the Gateway to some garbage, see picture one
I shut the radio down and disonnected the Ethernet cable and set the Gateway to 192.168.0.1(which is correct) the other Radio and Ethernet information is correct. Then I did a power off and reconected the thernet after the radio started and the Gateway for the Ethernet changed back to the garbage.
Picture after change to 192.1680.0. I have a cox wife router and wirelss mesh network with port fowarding to 192.168.0.230. It has worked in the past, Why does the Gateway keep changing? Any guesses?
Thank You
Chuck Bigbie N5ANY
- 637 The Flea Market
- 144 SmartSDR+
- 433 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
