The radio doesn't work well. The software doesn't work well
What a tremendous disappointment!
Well, is there a red x on the task bar speaker icon? If so connect a speaker or select another default.
Or uninstall and reinstall SSDR.
See if any of that works.
John N1JM
-1 -
The reason might be our old arch enemy Core Isolation. A PIA on laptops sometimes.
If you get the "DAX Driver Error" message after installing SmartSDR on a CLEAN Windows 10/ 11 installation, first check the "Memory Integrity" setting under "Core Isolation". If it is enabled, disable it. The DAX drivers do not need to be reinstalled, a reboot of the machine is sufficient.
There are various ways of doing this depending on the Windows version (I've helped a couple of G friends with this trouble). I do not have screenshots of their relevant settings but here is mine
This is just a possibility. The cast iron solution is to open a Help Desk ticket. Flex will sort it out for you.
-1 -
There's no red X on the speaker icon.
I'm disappointed that an uninstall doesn't really uninstall everything. If I re-install, all my settings are there, etc. So if there's a bad setting, an uninstall won't help because they're still in the machine, somewhere.
-1 -
Core isolation is off.
-1 -
Time to submit a help desk ticket, I would say.
John N1JM
-1
- 310 Community Topics
- 566 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 385 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 108 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 841 Genius Products
- 433 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 267 Shack Infrastructure
- 188 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
