No stations are online. Start a client and then choose a station from the list.
I tried uninstalling it an reinstalling several times.
Now it's saying "No Stations are online. Start a client and then choose a station from the list." As you can see from the screenshot, SmartSDR is running and connected fine., the DAX button is pressed.
There are no stations listed in the Station dropdown. I'm signed in to SmartLink and SmartSDR is working fine.
Do you have a DAX channel selected in your Slice receiver drop down? When you start DAX it should show what radios are available to connect to. One other thing to check is to see if your Firewall in Windows is blocking DAX for some reason. Temporarily turn off your firewall and see if DAX sees the radio when it starts up.
I've been trying for several weeks and can't get this software to work on my Windows 11 laptop.
I can get it to work on my desktop.
I've uninstalled and re-installed about 10 times. Uninstalling is a LIE. It doesn't uninstall everything because if I run the software after a re-install it remembers my settings. I'd expect a full uninstall/reinstall to wipe the settings, too, so a person could start from a clean, known state.
There's no DAX sound device showing up in the control panel. Audio works fine out of the SDR app, but I can't get DAX to do anything,
I believe that you need to turn off core isolation for DAX to work under Win 11. If that does not help, submit a help desk ticket - Flex Support will know what to do.
-1 -
It's off. I follow instructions, and read the documentation.
-1 -
Open a Help Desk ticket.
73Dave wo2x
-1
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
