Is it possible to run CWX On the Flex Maestro C ?
KG5PTE
Hi, I have been looking for some you tube videos on the CWX feature with the Flex 6400 and if this feature is available on the Maestro C as well. Or is this only with a PC ?
Thank you
Sort of.
You have to program the Strings you want to send into the Function Keys.
I found this thread due to searching for the same thing. Following the directions above I have the F-keys generating a sidetone but the radio doesn't go into transmit when I use them. I've confirmed the mode is set to CW, TX indicator is on, nothing is connected to the PTT jack and MOX is functioning. What am I missing?
In case someone with the same issue happens upon my post above, it was solved by performing a cold boot on the radio.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
