Is it possible to run CWX On the Flex Maestro C ?
Hi, I have been looking for some you tube videos on the CWX feature with the Flex 6400 and if this feature is available on the Maestro C as well. Or is this only with a PC ?
Thank you
    Sort of.
    You have to program the Strings you want to send into the Function Keys.
  • Rick N0VT
    Rick N0VT Member ✭✭✭
    edited September 2024
    I found this thread due to searching for the same thing. Following the directions above I have the F-keys generating a sidetone but the radio doesn't go into transmit when I use them. I've confirmed the mode is set to CW, TX indicator is on, nothing is connected to the PTT jack and MOX is functioning. What am I missing?
  • Rick N0VT
    In case someone with the same issue happens upon my post above, it was solved by performing a cold boot on the radio.
