Is it possible to run CWX On the Flex Maestro C ?
KG5PTE
Hi, I have been looking for some you tube videos on the CWX feature with the Flex 6400 and if this feature is available on the Maestro C as well. Or is this only with a PC ?
Thank you
Sort of.
You have to program the Strings you want to send into the Function Keys.
I found this thread due to searching for the same thing. Following the directions above I have the F-keys generating a sidetone but the radio doesn't go into transmit when I use them. I've confirmed the mode is set to CW, TX indicator is on, nothing is connected to the PTT jack and MOX is functioning. What am I missing?
In case someone with the same issue happens upon my post above, it was solved by performing a cold boot on the radio.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
