Maestro "C" sidetone too weak
Hi, the sidetone of my Maestro C (Software 3.7.4) is too weak when using the internal keyer with a paddle or a straight key. I know how to set the sidetone level and it is already set to 100%. Nevertheless, when the band or the environment is noisy, I would prefer to have a much louder sidetone.
I could turn down a loud sidetone to a comfortable level, but currently I am lost in loud environments.
Is there a way to increase the sidetone level?
The Speaker in the Maestro is pretty small. What if you used powered external speakers.
The speaker audio is pretty audio, but likely not enough in a noisy environment. To try to drive it with more power will likely cause distortion.
I gather you can't use headphones?
Hi, thanks for your comment. This would help in a loud environment. As an external speaker cannot distinguish between the signal and the sidetone, the SNR would not be changed.
In fact, the receiver output is much louder than the sidetone, even with 100% sidetone level.0 -
You might try resetting the radio and see if that helps.
I have the same problem. I have reset the radio but no difference.
I think it came up when I upgraded to version 3.7.4,
but I don't want to downgrade.
Any suggestions what to do ?
Hans SM6BGA
Hi,
the problem is an issue of the Maestro, not of the radio. The sidetone is generated locally and then fed into the audio stream. I believe, a software upgrade with different settings of the audio mixer could solve the issue.
73 de Micha, DF4WX0 -
Perhaps they changed the settings in version 3.7.4
Please change back !
Hans SM6BGA
no news ?
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
