My 80 meter band button quit working
kc9qje
Could use a bit more info… is this a button on a radio, amp, tuner, ant switch? A physical button or a button on a computer (Windows, Linux, Mac?) screen?
windows using smartsdr. If I select the 80m band button nothing happens other than the tuning flag disappears0
button on the 65000
You should be able to click on the icon in the lower left of SmartSDR and select add slice receiver. It is possible that the slice receiver is off screen. If that's the case, you should see in one corner or the other of the panadapter an arrow ( < > ) pointing to where the slice receiver is located relative to the current display. Left click and hold in the middle of the panadapter and drag in the opposite direction and the slice receiver should reappear.
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
