RX EQ not working with remote
Geoff AB6BT
Member ✭✭✭
I have SSDR installed on a remote PC that I connect to my 6600 at home using ZeroTier and a Raspberry Pi layer 2 bridge to my home network.
Everything works but I cannot get the EQ to have any effect.
What am I missing?
have you turned it on and not just adjusted the EQ settings…easy to forget..
pics help people help you when they can see how things are setup
PaulK3SF
Paul…the EQ is ON (Blue) I have RX selected (Blue) and when I move the sliders there is no change in the audio I hear.
Hi Geoff, what mode are you seeing this behavior? When selecting DIGU, DIGL or RTTY, the equalizer is out of the signal path.
Len…I was in CW mode. But it was the same in USB.
- 391 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
