RX EQ not working with remote
I have SSDR installed on a remote PC that I connect to my 6600 at home using ZeroTier and a Raspberry Pi layer 2 bridge to my home network.
Everything works but I cannot get the EQ to have any effect.
What am I missing?
  • K3SF
    K3SF Member ✭✭✭
    edited August 2024
    have you turned it on and not just adjusted the EQ settings…easy to forget..
    pics help people help you when they can see how things are setup
    PaulK3SF
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Paul…the EQ is ON (Blue) I have RX selected (Blue) and when I move the sliders there is no change in the audio I hear.
    Hi Geoff, what mode are you seeing this behavior? When selecting DIGU, DIGL or RTTY, the equalizer is out of the signal path.
  • Geoff AB6BT
    edited August 2024
    Len…I was in CW mode. But it was the same in USB.
