How to build FlexLib using Visual Studio 2022 Community edition
Like Steve mentioned in a earlier post I'm on an adventure to build some custom software that interfaces to the Flex 6000 and 8000 series radios and I have a similar question.
Can FlexLib be built using Visual Studio 2022 Community edition?
As James mentioned above coping the precompiled DLLs will work just fine, however for my own knowledge and satisfaction I want to build FlexLib from source. When I try to do the build in Visual Studio 2022, I get the following errors:
CS8137: Cannot define a class or member that utilizes tuples because the compiler required type 'System.Runtime.CompilerServices.TupleElementNamesAttribute' cannot be found. Are you missing a reference?
I'm new to C# so there's probably something simple I'm missing here. In reading and watching YouTube videos over the past couple of months I've learned how tuples are handled by Visual Studio C# changed between .NET 4.6.2 and .NET 4.7.
Reading through some older posts they indicated that Flex was using Visual Studio 2010 to build FlexLib / SmartSDR and I'm wondering that is still true or have they moved to a later version of Visual Studio. If possible, I'd like to use the latest toolchain, so I don't get painted into a corner as newer versions of Visual Studio come out.
73 and good DX,
de Roger, NK1I
Hi Roger, I am using Vidual Studio 2019 without issue so I would guess that 2022 will be fine.
I don't know about tuples, so I am not much help there.
I have some example C# FlexLib programs on Github if you want to check them out. FlexRepeaterSpots is done and working well. Flexicraft Utility is a work in progress. I expect to post a usable version of it later this week.
Roger, if you have kept Windows and Visual Studio updated, you should be able to compile the dll's without any problems. But, you have to do it in a particular order ( I don't recall what the order is at the moment) and then link the compiled dll to to each new dll as you progress.
I look at the source code for each dll tounderstand what values each one requires and what format is expected. But, as you mentioned, instead of compiling each dll I just copy the needed dll's from the SmartSDR install folder and create a folder in my project and paste the copies there. Then, just reference the dll's in my project.
I do it this way because there have been times in the past where Visual Studio's Intelisense didn't make sense to me. Looking at the source code of the dll I was working with, seemed clearer to me.
I haven't tried the VS2022 community edition lately against FlexLib, but I wouldn't expect to have problems as we are using VS2022.
2
- 384 Community Topics
- 648 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
