New User: Flex 8400 Current Draw?
kq4tnf
kq4tnf Member ✭✭
I am about to do the deposit on the 8400 but wanted to see if anyone knows what the current draw is on the 8400? I did not see that information on the spec sheet. Im wanting to plan the purchase of a power supply for this and am trying to figure out what size to get.
Best Answers
    Answer ✓
    I am a fan of buying more power supply than you need to accommodate additional gear. I am way overkill with a 70 amp Astron, but a 45 amp unit will fill the bill and provide enough headroom for just about anything else that you might want to power in your shack.
    edited July 2024 Answer ✓
    Here is what we recommend.
    Using a 20A Astron is not recommended for full power operation.
    25A is highly recommended and the PowerWerx we sell does a great job (I power both a 6500 and a 6600 at the same time). This is the minimum current rating.
    And, of course, anything greater than 25A is not a bad idea either. It depends on your budget.
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    Is it your first 100W TRX for Short Wave?
    PSU like all other TRX on market if the have a max. output off 100W = PSU with 25 - 30 A !!!!
    Chris DL5NAM
  • Al K0VM
    Al K0VM Member ✭✭✭
    Same as 6400.. 25-30 amps on transmit.
    AL, K0VM
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    The PSU Flex sells, 25 amps continuous, 30 amps max, is entirely adequate.
  • kq4tnf
    kq4tnf Member ✭✭
    Yes to the questioin on this being my first trx! looking forward to this
  • Johan SE3X
    Johan SE3X Member ✭✭✭
    As Len I prefer a bit of headroom and use a 50A for my 6700. If you are running barefoot 100W a 25A will have to work hard, a 45-50A not so much.
    73, Johan
    Been using Flex’s 25 amp PSU daily for 6.5 years, sometimes for weeks at a time, without a whiff of a problem.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Average power draw depends on mode. SSB is very peaky, averages about 30% power overall, if peakes are at max power.
  • Ken Wells
    Ken Wells Community Manager admin
    If I had more than one radio, I would rather have TWO 25-30 Amp supplies than ONE 50-60 Amp supplies….
    WHY? Of one of them goes bad, you still have one that will power at least one of your radios, keeping you on the air.
  • Johan SE3X
    edited July 2024
    Agree 100% with you Ken, redundancy is very important. That's why I have my 50A connected with only 20cm wires from the PS to the radio. To minimize losses betwen PS and radio and my main PS.
    Then I have a second 30A PS powering things like remote switches etc. that in case of a main 50A PS failure could be switched in to my 6700 in less than 2 minutes.
    Is it likely that both goes bad at the same time? Well maybe after a thunder strike? But I guess than the station might be history anyway.
    I guess I’m just lucky, but in almost 60 years as a ham I’ve never had a power supply fail (other than a bulb on an Astron lighted meter model).
  • ka9ees
    ka9ees Member ✭✭✭
    My 40 yr old Astron RS35M failed a few months ago. Transformer primary developed a dead short. So it does happen.
    All my Astrons have failed now. :) Some lasted 20 years, some less.
    Needless to say, I don't own any of them anymore.
  • ka9ees
    ka9ees Member ✭✭✭
    I like Astron supplies. I now have a rebuilt Astron 35M rack mount. It had a shorted pass transistor, and a 30 amp Powerx as a backup.
  • This content has been removed.
    Russ, you should check the pricing of the RS-70 now. It is well over $550 and since it weighs about 50 pounds, they don't ship it for free. :)
    But, yes, it has a 5mv ripple compared to most that have <100mV (p-p). Is it worth it? As an operator, would a 100mv ripple impact my daily operation in any way?
