PGXL Utility DHCP Address
When I set the PGXL IP Address checkbox to DHCP in the PGXL Utility, it sets the subnet mask to 0.0.0.0 and the Gateway Address to 0.0.0.0. I checked it against the TGXL Utility, which when DHCP Addressing is checked shows the subnet mask correctly as 255.255.255.0 and the Gateway Address as 192.168.1.1. I think something is wrong here but I don't know what it is. My router has DHCP Reservations for both of these devices.
If you can operate the amp from the app with the amp in DHCP, then it is getting then proper IP, netmask, and gateway, even though it shows zeros.
Dave wo2x0
Firmware Versions are PGXL 3.8.8 and TGXL 1.2.11.
after setting PG. L to DHCP, save & reboot via app. Then remove power or turn off rear power switch for 30 seconds.
73 Dave wo2x
Tried it. Doe not do anything.
The only way I can get the subnet mask and gateway addresses to read 255.255.255.0 and 192.168.1.1 is to select Static Addressing and enter these values. When in DHCP Addressing the subnet mask sets to 0.0.0.0 and the Gateway Address sets to 0.0.0.0. Saving DHCP, rebooting via the app (which is the same as saving) and then turning off and restarting the PGXL does not change anything. As I said previously the TGXL does not behave this way.
I suppose you have checked to make sure your Router DHCP service is enabled on the Router and set up properly to hand out the correct IP range, Netmask and DNS addressing?
Yes the service is enabled and set up correctly in the router. As evidence of this the TGXL DHCP box is checked in the TGXL Utility App and the TGXL Utility App reports the subnet mask as 255.255.255.0 and the Gateway as 192.168.1.1.
OK. Mystery solved. I had reported this to the Flex Help Desk and Ken replied that it is a bug in the PGXL software that affects the Mask and Gateway display in the Network tab and that if the amp is operating correctly it is not an issue. Does anyone know if these known bugs are reported anywhere on the Flex website? If so I would like to know where that is and if not it would be great if they could be reported somewhere.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
