No decoding bellow 50.100 mhz
Hi all,
For some reason can't get decoding to work on sdc below 50.100 MHz. I'm using flex-6300 and smart sdr for mac os. Any ideas? Settings in the video.
https://youtu.be/Sun-gnjBR1s?si=na2hpnSh2pGPgwO4
Best regards, Kes m0pkz/ly3k
  • Erik Carling EI4KF
    I cannot tell from your video. If it is a SDC setting, what do you have for 'from freq' and 'to freq' in Skimmer Global > Band Plan for 50mHz? 50000 / 50150 / ALL would be right and mean it is something else.
  • Martin_G4ENZ
    Martin_G4ENZ Member ✭✭
    edited June 2024
    Kes,
    Your Skimmer bandwidth is 48kHz and your Panadapter is centred on 50.125. You will only decode 50.101 - 50.149 with these settings.
    73 Martin
  • Kes-m0pkz
    Kes-m0pkz Member ✭✭
    Hi all,
    I can change to 96000 (this is still not enough for 20m band), but then I change to 192000 SDC  skimmer window crashes.
    I am running a mac mini m1 8gb ram.
    Regards, Kes.
  • Kes-m0pkz
    Kes-m0pkz Member ✭✭
    Hi all
    https://youtu.be/Q4lMqHGvGh4?si=K4Z6owZxT9pVO9LB
    Running a Mac mini m1 8 GB of ram
    Regards, Kes.
    edited June 2024
    Match in SDC the rate defined in SSDR. 96000 for both.
    If you use Adaptive SKM (SmartSDR API tab in SDC) – the channel IQ is matched with the Skimmer frequency plan. I omitted to to point that out. See the manual for details. Ask Yuri by email if there is any residual misunderstanding and he will help.
