No decoding bellow 50.100 mhz
Hi all,
For some reason can't get decoding to work on sdc below 50.100 MHz. I'm using flex-6300 and smart sdr for mac os. Any ideas? Settings in the video.
https://youtu.be/Sun-gnjBR1s?si=na2hpnSh2pGPgwO4
Best regards, Kes m0pkz/ly3k
I cannot tell from your video. If it is a SDC setting, what do you have for 'from freq' and 'to freq' in Skimmer Global > Band Plan for 50mHz? 50000 / 50150 / ALL would be right and mean it is something else.
Kes,
Your Skimmer bandwidth is 48kHz and your Panadapter is centred on 50.125. You will only decode 50.101 - 50.149 with these settings.
73 Martin
Hi all,
I can change to 96000 (this is still not enough for 20m band), but then I change to 192000 SDC skimmer window crashes.
I am running a mac mini m1 8gb ram.
Regards, Kes.0 -
Hi all
I can change to 96000 (this is still not enough for 20m band), but then I change to 192000 SDC skimmer window crashes.https://youtu.be/Q4lMqHGvGh4?si=K4Z6owZxT9pVO9LB
Running a Mac mini m1 8 GB of ram
Regards, Kes.0 -
Match in SDC the rate defined in SSDR. 96000 for both.
If you use Adaptive SKM (SmartSDR API tab in SDC) – the channel IQ is matched with the Skimmer frequency plan. I omitted to to point that out. See the manual for details. Ask Yuri by email if there is any residual misunderstanding and he will help.
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
