Possible Maestro C Bugs
Noticed 2 things with my new Maestro C
- Battery indicator suddenly is sitting at 96% charge even with battery removed and running on AC only
- To get vox to work when first turning on Maestro I have to hit tune button first then the vox will work properly.
Comments??
To have this correctly tracked, please open a support ticket.
I don't see the 96% issue or anything similar and run with my battery out all the time. Does it go away if you reboot? If so, we need to know that. I was not able to recreate the same issue.
So I unplugged power and let it run on battery and got to 80%. Plugged back in and it charged to 100%.
It did not clear upon rebooting. It stayed at 96% for 2 days. Only way to get it to work properly again was disconnect ac supply and let it run on battery. When it hit 80% it charged up normally to 100%
If it helps, Mike, I have the same issue. My Maestro stays plugged in much of the time, so it's not really a problem for me. If I leave it unplugged and run the battery down to, say, 75%, I can charge back to 100%.0
I can't say for sure, but possibly at 96%, the battery/supply don't think it needs to go into 'charge mode' and just keeps running. When you run on battery and get it say, below 80% then it decides it needs to recharge?
I am also seeing that the Maestro C battery does not charge above 96%. There is no indication that the battery is charging even though the power supply is connected to the Maestro and powered up with a blue LED on the charger. It would be nice to have the battery icon change when it is charging.
FWIW, my Maestro C charges to 100% reliably. I've never seen this issue with mine. N6ATC
The battery in my Maestro C does not seem to be charging at all. I tried the discharge method but it still does not charge. Right now it is sitting at 77% and no indication it is charging.0
Allen I would do a support ticket on this one.
My Maestro charges to 100% using my home brew 18V charge cable that connects to one of the DC to DC buck converters to charge from the Shack 13.8V power supply plugged into the radio.
Maestro C Konsole neu , bootet nicht, grüne LED blinkt, Reset nein
73 Ronald DL1RME DM7D0
- 375 Community Topics
- 103 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
