S.A.T Self-contained Antenna Tracker
tgiro01
tgiro01 Member ✭✭
Those of you using a 6600 with vhf and uhf transverters - has anyone used the S.A.T Satellite Antenna Tracker from CSN Technologies — http://www.igatemini.com/sat
It's designed to control ICOM rigs, but it will work with a Yeasu AZ/EL rotator to track the birds. I don't think it needs to be connected to the radio to work. From what I see, it merely controls the frequency setting on the radio.
If it works as advertised, it would reduce the amount of rotator tuning needed to keep a bird in range.
  • Alan
    Alan Member ✭✭✭✭
    The CSN S.A.T device will not interface with a Flex Radio.
    I provided CSN with a easy to implement method to interface with Flex and they have so far not added same to their firmware.
    Alan. WA9WUD
