Connecting cables for transverter ?
I what cables/connectors do I need for hooking a transporter to the 6600 ? I can see the connectors on the back of the flex but not sure what to order and what gender.
Andy K3UK
Oh, it is simply a BNC.
50 Ohms cable terminated with a male BNC (Flex side) to whatever is the transverter input connector.
Something to remember, Just like N Connectors BNC connectors come in both 50 and 75 Ohm flavor connectors, The easiest way to tell them apart is the Center Pin on the 75 Ohm connectors is a SHARP very small needle.
I did not know that ! Thanks
FWIW — I just measured the center pin diameter on both a 50 Ohm and 75 Ohm male BNC.
They both measure 0.053" diameter.
The 50 Ohm and 75 Ohm connectors do mate with no physical damage.
You are right, Geoff.
They have the same mechanical interface specification MIL-STD-348.
- 368 Community Topics
- 628 The Flea Market
- 8.1K Software
- 80 SmartSDR+
- 421 SmartSDR for Mac
- 270 SmartSDR for iOS
- 189 DAX
- 33 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 914 Genius Products
- 331 Tuner Genius XL
- 450 Remote Operation (SmartLink)
- 778 Peripherals & Station Integration
- 993 Third-Party Software
