Connecting cables for transverter ?
Andrew O'Brien
Andrew O'Brien Member ✭✭✭
I what cables/connectors do I need for hooking a transporter to the 6600 ? I can see the connectors on the back of the flex but not sure what to order and what gender.
Andy K3UK
  • Andrew O'Brien
    Oh, it is simply a BNC.
  • N5NHJ
    N5NHJ Member ✭✭✭
    50 Ohms cable terminated with a male BNC (Flex side) to whatever is the transverter input connector.
  • Andrew O'Brien
  • WX7Y
    WX7Y Member ✭✭✭✭
    Something to remember, Just like N Connectors BNC connectors come in both 50 and 75 Ohm flavor connectors, The easiest way to tell them apart is the Center Pin on the 75 Ohm connectors is a SHARP very small needle.
  • Andrew O'Brien
    I did not know that ! Thanks
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    FWIW — I just measured the center pin diameter on both a 50 Ohm and 75 Ohm male BNC.
    They both measure 0.053" diameter.
    The 50 Ohm and 75 Ohm connectors do mate with no physical damage.
  • N5NHJ
    N5NHJ Member ✭✭✭
    You are right, Geoff.
    They have the same mechanical interface specification MIL-STD-348.
    https://www.amphenolrf.com/rf-connectors/bnc-connectors.html
