I have a new Maestro "C". I have the sidetone turned all the way up and I cannot hear it.
I have reset the radio (remove power supply wait 5 min plug in ps while holding the start button down) Radio resets, boot Maestro and have sidetone volume set to 100, I only barely hear it in my headset and not at all on the speaker. My previous Maestro (B) would **** me out of the chair with sidetone. What's up?
with your headset unplugged, can you hear it on the Maestro’s speaker?
No, nothing changes when the headset is unplugged. You can just barely hear the sideton in there and it is the same level on both the speaker and headset. A bit of a disappointment since the Maestro is the ONLY way to get a sidetone when using a paddle. (Yes, I know there are workarounds but this should function as advertised)
Thanks for the response.
73's Joe K8FC
The CW Sidetone does work, so we want to explore that some setting may be incorrect.
While in CW mode, can you post a screen shot of the TX MENU.
And, I have to ask, your Paddles are plugged into the Maestro or the Radio?
thanks
The side tone is weak on my Maestro even with the mon level all the way up
Mike, thanks for the response. Screen shot of Maestro included and paddles are plugged into the back of the Maestro.
I'm afraid I cannot help you, but I can provide some hope - my Maestro C achieves same audio level as the station I'm listening to, filling my small ham-shack nicely. Here's a short clip with my "5"s being the equal of W1AW (no, I'm not transmitting atop W1AW :-O )
Summary - I find my Maestro C internal speaker is quite OK, with Sidetone level at 80
(Apple will auto-expire this link in 30 days. And Flex's forum won't accept anything other than still images. So enjoy now, or download/save for any duration you like. Sorry, later Googlers)
Please open a support ticket. thanks
Something unique is wrong with yours.
Good morning, Gord. Thank you very much for your support. This is a temporary problem and when I can devote more time to researching the issue, it will get resolved. If I am reading these presponses correctly, I am not the only person experiencing this issue. It will get solved soon, I am sure.
73's
Joe K8FC
Support ticket created. 73
Thank you for this quick response. After taking some time this morning reproducing the issue, I want to give you some additional information. I have the ability to log into a remote Flex 6600 using smart control and my Maestro. With that radio, I can hear the sidetone but not loud. I can raise the sidetone volume (using the Maestro TX menu) to 100 it is only marginally better.
Joe0 -
add that to your ticket.
I copied you and the ticket in when I responded Mike.
- 256 Community Topics
- 492 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 792 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 739 Genius Products
- 395 Power Genius XL Amplifier
- 257 Tuner Genius XL
- 87 Antenna Genius
- 225 Shack Infrastructure
- 152 Networking
- 119 Contesting
- 589 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 817 Third-Party Software
