Mic PTT Transmit question.
Hello. when I am using the Flex 6400 mic (Or in my case the Heil HS-2 PTT switch and the Shure Beta 58 Mic) where on the Maestro C do I choose the mic ? As of right now I have no Mic or PTT or anything plugged into the 1/8 jack in the back. I am using the Maestro with the Flex 6400 here in the shack and is plugged into my network switch.
Thank you
If you are still close enough to the radio, you will get the best audio, lowest latency, and greatest reliability by connecting the Mic, CW Keys, Speakers, Headphones, and PTT to the RADIO, rather than the Maestro.
Select "R-MIC" or "R-BAL" for the Mic input selection in the Maestro TX MENU.
If you are connecting a Mic to the Maestro's HDST jack, then you would select "HDST" from the TX MENU "Mic selection menu" on the left-hand side of the TX MENU.
Thank you. I had the Maestro C in M-HDST last night during our 40 meter HF net. I have changed it to R-Mic (I think the R- mean radio). Yes the Radio and Maestro are right here in the shack next to one another. But yes I would rather key the mic plugged into the radio than the Maestro here in the shack. I believe the instructions are on page 183 and 184 in the manual. But wanted to make sure.
Thank you.
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
