6600M 60 meter out of band
Until today, I was able to transmit on the US channels. Now, I am unable to do so. The frequencies that unlock are 5330, 5346, 5357, and 5371. The authorized channels show, "inhibit is out of the band."
Any suggestions?
Len, K6ANP
  • David Decoons, wo2x
    transmit BW needs to be 100-2700 or less. Check mode. If using WSJT-X, uncheck Fake It or Split in settings/radio tab
    Make sure transmit is selected on slice flag.
  • K6ANP
    K6ANP Member ✭✭
    I checked all your suggestions and found them okay. I don't understand why I'm able to transmit on unauthorized frequencies and not the legal ones.
  • Erika - KØDD
    Erika - KØDD Member ✭✭✭
    Lets just talk about 5.357... if you should be able to throw a tune signal on 357 if you have digiu selected and even zero and 3000 in the transmit width. Bump it up 100 on the bottom and down 100 on the top 2.8. Should be just fine. You only have a very small window to fake it where your transmit doesnt shift. Conventional f/h will not work. Usually expeditions are learning flexes have this limitation. Now if you were to flip over to usb you would be able to talk... as usb goes north. Some radios offset my yaesu ft450d worked on the centerline of the channel. But once i enabled general coverage i had to use the bottom edge and ssb up.. youll get used to how the world works. Dont worry about being out of the channel because you're not. The turf file will keep u locked out. K0DD
