No SSB transmit audio when using the MOX button
I have a Flex 6400M and when I push the MOX button on the face of the radio, the radio keys up, but I can't transmit SSB. When the button is pushed it glows RED and puts the radio in the transmit mode, but when I talk into the microphone there is no RF output or any meter movement at all. The radio works fine other wise like if I use the PTT on the microphone or use VOX. What am I doing wrong?
Thanks, Bob W6MTM
Glad you have it figured out.
I have a feature request in that if I do a hardware PTT (handswitch/footswitch sort of thing) that DAX is turned off for the transmission.
We then have to figure if doing that breaks something else.
No promises of if and when.
DAX TX enabled?
I am not sure if MOX overrides DAX TX audio to use mic audio. The RCA PTT in does override DAX TX audio.
Dave wo2x0 -
Ho Bob, in addition to Dave's question, do you have the proper mic jack selected?
You guys have to read what I said. I am using the Flex 6400M sitting in front of the radio, not using a computer or Maestro. I am sitting using this radio as if it were an ICOM 7300 or Yaesu FT-101B or Kenwood TS-440. All I would like to know is why am I not able to transmit audio on SSB? I can switch to CW and turn off Break IN and push in the MOX button (turns RED) and I talk into the microphone or headset mic. and there is no transmitted audio. I see no power indication on the watt meter and there is no scope indication either. So, there you have it a complete mystery to me. Thanks guys, Bob
Hi
I think that Len's question is still valid. You do have to select the correct Mic Input, insure that the Mic gain is set correctly and that TX DAX is off.
Unlike other radios, there are multiple mic input options. You do have to set the correct MIC input.
Also, is this a Maestro A/B or C as there are differences in the MIC connector.
I have highlighted a few things that can cause your situation:
- The MIC may or may not require BIAS
- Turn on Level Meter During Receive so you can see if MIC audio is working while in RX (why doesn't every radio do this? )
- Must be in USB or LSB
- Pick the correct Mic Input - this picture is from a Maestro C, but you want to look for a selection beginning in M- (lower left)
- Set your MIC Gain to 1/2 way
- DAX is off
- Level Meter shows you Mic level - very critical.
You can get to the menu that adjusts these things by pushing the button labeled TX MENU on the right side. You end up pushing in the button that adjusts the MIC gain.
TAP the bar graph meter until you see LEVEL for MIC LEVEL. Very powerful meter and set it so your voice peaks at about -5db.
Thanks guys so much for helping me out on this problem. As it turns out, I just needed to push in on the MIC/SPEED knob and that brings up the menu where I did see the DAX was enabled. I disabled DAX and now using the MOX button to transmit on SSB works just fine. Thanks a TON guys, you all are awesome!!!!
Best regards, Bob Meadows W6MTM
I'm having similar issues. Footswitch PTT plugged into Maestro C Mic2-PTT. R-Bal mic input selected on Maestro as microphone is plugged into 1/4" socket on back of 6600M. DAX is off.
When footswitch is depressed, no mic output.
When MOX on Maestro is depressed, full mic output.
Please advise so I can use the footswitch. Thank you.0 -
If you want to use the balanced input on radio, plug the foot switch into the radio and not Maestro. Set mic to R-Bal
To say what Dave said another way ..
The MIC and PTT have to be on the same device. You can't have PTT on the Radio and MIC on the Maestro (or PC).
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
