Trying to set up HRD. I get the error "SmartSDR CAT requires FlexVSP Service
Jim Miller
New 6400M owner, and trying to set up HRD. I get the error "SmartSDR CAT requires FlexVSP Service to be installed and running." What do I need to do next?
I believe FlexVSP gets installed when you install the SmartSDR software that also includes CAT and DAX. CAT also has to be running I believe.
Tim N9PUZ
This is correct, VSP is installed with Smart SDR install.
Under the task manager, one should see the process "Virtual Serial Port Kit" if VSP is installed properly and running.
There is an install .MSI file for VSP in the SSDR install s/w directory...
k3Tim0 -
THANKS!! Task Manager does not show Virtual Serial Port Kit. I just now have reinstalled Smart SDR. I'll try it again.
Jim
WA5TEF
i have same issue, i went into the install directory and ran the "FlexVSPInstaller_32" But i still get same error. And the service does not show up in task list, nor in services.
I am trying to install Windows SDR on M3 Mac running Parallels Desktop Pro. I saw another thread where someone was able to run SDR in Parallels. Any ideas what to try next.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
