Trying to set up HRD. I get the error "SmartSDR CAT requires FlexVSP Service
I believe FlexVSP gets installed when you install the SmartSDR software that also includes CAT and DAX. CAT also has to be running I believe.
Tim N9PUZ
This is correct, VSP is installed with Smart SDR install.
Under the task manager, one should see the process "Virtual Serial Port Kit" if VSP is installed properly and running.
There is an install .MSI file for VSP in the SSDR install s/w directory...
k3Tim0 -
THANKS!! Task Manager does not show Virtual Serial Port Kit. I just now have reinstalled Smart SDR. I'll try it again.
Jim
WA5TEF
i have same issue, i went into the install directory and ran the "FlexVSPInstaller_32" But i still get same error. And the service does not show up in task list, nor in services.
I am trying to install Windows SDR on M3 Mac running Parallels Desktop Pro. I saw another thread where someone was able to run SDR in Parallels. Any ideas what to try next.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
