Change assigned DIV slice?
Hi
When turning on Diversity (DIV) on a 6600 this always defaults to slice D, is it possible to change this somehow? Or can you do something to manually move it from D to B?
I've only got Slice A open when clicking on DIV so it's not picking the next available slice, it is always D regardless of what else is open.
Rich
    Answer ✓
    I had to get in front of a radio to check.
    With SmartSDR it likely opens the last slice and that is a D for a 6600 and likely H for a 6700.
    On a Maestro it is labeled DIV
    I am not in front of radio, but I am pretty sure mine goes to the next available, usually B.
    If you reboot the radio, does it behave the same way?
    You are not running MultiFlex at all?
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    Hi Mike
    So I just had Slice A open (DIV turned off), closed SmartSDR and rebooted the radio, re-loaded SmartSDR, Slice A opens, clicked DIV but it's still going to Slice D.
    With and A and D open, clicking to open a new slice opens B.
    I then close DIV - Slice D and enable it and it opens D again.
    I can't get DIV to open the next available slice, no matter what combo I choose.
    Not using MultiFlex. Running SmartSDR 3.7.4
    Reason for wanting to use B is I have some USB ports in use for some switching and these are configured for Slice B so need DIV to use this to make it fit with the existing set-up.
    Rich
  • Rich M5RIC
    edited April 2024
    Thanks Mike, least we are seeing the same. I assume this is hard coded and can't be changed?
    From a Diversity perspective, if I were to use Slice B plus some third party software to track the frequency so B follows A, would that achieve the same as what the DIV button does? Is there any reason not to use this method?
    I know I'd have to manually set the audio so A is in left ear and B is in right again that is easily done with streamdeck or other software with a push of a button.
    It is hard coded.
    It should do the same thing. You will have to give it a try.
    RXAssist might help you a bit too.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    I can confirm that DIV uses slice H on a 6700.
