Antenna Genius and Icom radios 60 meter problem Any workaround?
Ken D'Alessandro
Antenna Genius works perfectly with my Flex 6600. I have an Icom 7300 that outputs band data as CI-V as do all other Icom radios. Antenna Genius does not have CI-V as an input choice and the BCD drive choice (see Antenna Genius Manual Ver. 4.1.0 rev1 at page 23 of 56) does not have an entry for 60 Meters and states that it is not possible to select 60 meter band through BCD. Does anyone have a workaround for this?.
This should solve your issue.
It will then generate the band data you need from Icom's CI-V data stream.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
