The S-meter for SmartSDR is available.
2»
  • Member ✭✭
    edited December 2016
    Gary, thanks for your info, but I'm still cannot get it to work.
  • Member ✭✭
    edited July 2016
    downloaded and the result ws 1.5 meters! Like one meter and 1/2 of another all together as one! I am not sure what is going on here?
  • Member ✭✭
    edited April 2014
    I run a 26 inch 1980 monitor and I donot have to increase the resolution to 125% I run 100% . Display is sharp and very readable. You might need to look and see if your tv on graphics card has the over scan option so you can adjust your screen to your monitor. Most newt vs/monitors adjust this auto actually. That will solve you meter problem
  • Member ✭✭
    edited December 2013
    Beppe, great work and the S Meter works well. Thanks so much for providing this to the community. 73's Charlie, WA3UTC
  • Member
    edited June 2020
    Hi, a new version is available at usual download page. Whats new: new graphics on numbers and backgrounds. 73 Beppe ik3vig woodboxradio.com
  • Member ✭✭
    edited October 2019
    Beppe, I Like the new features and the dual RX ability of the meter. Ps. On your web page please put a Euro to Dollar conversion to donate PayPal.
  • Member ✭✭✭
    I like it, Beppe. The larger numbers are much easier to read. Thanks a lot!.
  • Member ✭✭✭
    edited April 2020
    Mille Grazie 73 Chris
  • Member ✭✭
    edited October 2019
    Beppe, Thanks for providing the new S-meter. In my opinion the red over S9's are a bit oversized at the moment and do not match with the rest of the picture. 73, Albert
  • Member ✭✭
    edited October 2019
    What is the latest version number. I deleted and went to site to download. I do not see any change. Version I have shows 1.01.
  • Member ✭✭
    edited March 2014
    The latest 1.0.1.0 shows Signature Series, the old WoodBoxRadio.
  • Member ✭✭
    edited January 2015
    Download the one that is name "BobSmeter-Flex"
  • Member ✭✭
    edited January 2015
    Now that you mentioned it, you are correct. The black line is thinner and it appears as not a continuous solid line. However, for free it's a nice looking meter! Thanks Beppe
  • Member ✭✭
    edited January 2020
    Keith Pawley Here is how to get the S meter working; Go to:http://www.woodboxradio.com/flex6000.html Look for the following S meter "BobSmeter-Flex" and download it (remember where you put it or downloaded to the desktop) After downloading it - unzipped the file BobSmeter-Flex_v1 Open SmartCAT and set a pair of com/port i.e, 5-15 Look for BobSmeter file and run it The meter comes up - set the meter port to 5 every thing else should work. Make sure you check for handshake between the meter and SmartSDR CAT. Finally open the folder and look for "BobSmeter executable file and it will show on your desk top.
  • Member ✭✭
    Thank you very much it is now working kind regards Keith M0PAW
  • Administrator, FlexRadio Employee admin
    This is a great conversation that's separate from the main topic, so I created a new topic to continue the discussion. Please reference the new topic here: How to get the Woodbox Radio S-Meter working?
  • Was very unhappy to find out that I was unable to download from this site😢 ; Could someone forward to me at W2NDBAE@Gmail.com🌕
  • Member ✭✭
    Both links in this thread get a page not found.
    John N1JM
  • Member ✭✭✭
    edited March 2024
    Howard KY6LA shared the exe file with his Dropbox back in 2018. Seems it's still working:
    https://www.dropbox.com/s/223si9ks962n1av/Smart%20S-meter_V1.6.zip?dl=0
    Cut and paste and you should be fine.
  • Member ✭✭✭
    I have the Version 1.0.0.
    I just made it available for download here:
    https://www.dropbox.com/scl/fi/7eorkrva7b9mezgn6q589/Smart_SMeter_PLUS.zip?rlkey=7wwoq65d819a1y597h4n65w6a&dl=0
    It would be great if someone can share the latest version.
  • Member ✭✭✭
    edited March 2024
  • Member ✭✭✭
    What's the difference between Plus and v16?
  • Member ✭✭✭
    I think its actually ver 1.6 but the difference is 1.6 can run 4 instances of the meter to use with 4 slices.
  • Member ✭✭✭
    v1.6 doesn't show the VFO frequency while PLUS does..
    Plus is the same version I uploaded to Dropbox.
    The release note for both of them shows Rel 1.0.
    Based on the original post from Beppe, there should be a version with a different graphic.
    More info anyone?
  • Member ✭✭✭✭
    In the Meters Tab there is a selection for two different meter backgrounds. One the classic Kenwood analog meter with the white background and the other with a black background.
  • Member ✭✭✭
    Yes, but none of them looks like the one shown in the original posts.
